Brake pad POLL. For 37 inch tires.
Old Sep 14, 2010 | 10:02 PM
hardcoreoffroad's Avatar
Default Brake pad POLL. For 37 inch tires.
Brake pad POLL. wich pads to use for a Unlimited JK on 37 inch tires. This is a jeep that gets driven every day on hiway and city,with the occasional weakend trip offroad.
Hawk pads.
EBC GREEN pads.
EBC YELLOW pads.
EBC RED pads.
Let me know.
Old Sep 15, 2010 | 01:34 AM
Mark Doiron's Avatar
Originally Posted by hardcoreoffroad
Brake pad POLL. ...
I don't see a poll.
Old Sep 15, 2010 | 06:47 AM
john smack's Avatar
I run..... STOCK! and they work fine
Old Jan 10, 2011 | 05:00 PM
DesignMonkey's Avatar
more opinions on this one please... i am just about to order brakes. I run real heavy with all the add ons (tires/armour) and will be towing 3000lb trailer over the mountains several trips
help - i am lost
EBC yellow front and green rear
Hawk LTS all around
Hawk ceramic front and LTS back
Old Jan 10, 2011 | 05:14 PM
Stepsride's Avatar
No disrespect to the the person speaking of EBC brakes. HOWEVER if you turn your rotors and put EBC Yellow on your stock disks you MIGHT get 3000 miles before your disks are WARPED BAD. How do I know this.... DID IT!
You will need new rotors if you do EBC yellow.
I did the HAWK brake pads and DID NOT turn my rotors and there was a significant increase in brake performance. I know the Green 7000 pads EBC would probably perform as well as the Hawk.
FYI do not turn your rotors unless they are already have a warped rotor or have major gashes.
If you do rotors I like the EBC kits, Rebel Offroad has a great kit, THose 2 you cannot go wrong with rotors.
ENJOY
STEP
Old Jan 10, 2011 | 05:34 PM
Thanks STEP... yup i will be upgrading the rotors (fronts) for sure.
Old Jan 10, 2011 | 06:18 PM
DTJK's Avatar
So what rotors to use with EBC yellow?
Old Jan 10, 2011 | 06:53 PM
i am going with the EBC rotors - slotted and dimpled. Decided i did not want full drilled through (not sure if it will make a difference with the remote chance of cracking??) but i also see a few people like the Power Slot ones
Old Jan 10, 2011 | 07:11 PM
cfr's Avatar
cfr
If you're going to buy rotors, it would seem that you're partway to the Teraflex big brake kit,
http://www.quadratec.com/products/12...googlemerchant
Old Jan 10, 2011 | 07:42 PM
was thinking of that, but $650 CDN to just do the front is too steep for me and sounds like they are still testing..
