AeroForce Interceptor Gauge
Old Sep 15, 2010 | 05:39 PM
YingYang's Avatar
Default AeroForce Interceptor Gauge
Got my AeroForce gauge installed. Took me longer to mount the gauge pod than it did installing the gauge. Its a simple plug and play gauge. Plug into the OBD and your off. I need a masters degree to figure this thing out. It shows so many things, most everything your computer spits out. It does come with an optional white faceplate and silver trim ring. I liked the all black. Going to have a custom A pillar mount made but had this pod and it will serve its purpose for now.
Check out the specs here -
h t t p://www.aeroforcetech.com/products_interceptor.html
This gauge can even do some of the things my Superchips tuner can do, and some that it cant...
Low and high fan control
Transmission reset
ESP disable/enable
Tire size diameter
Idle speed
TPMS threshold
Rubicon model - Sway bar removal dash light disable
Axle Ratio
Read and clear trouble codes
0-60 time
1/8 & 1/4 mile speed
Old Sep 15, 2010 | 06:00 PM
Davebone42's Avatar
Is that black tube part of the guage deal or is it a grab bar? I have never seen that
Old Sep 15, 2010 | 10:45 PM
EarlyJk's Avatar
Looks good. Another option is mount it on the center console like this.
ID:	88941   Click image for larger version
Old Sep 16, 2010 | 03:26 AM
Strutssound's Avatar
Here's my solution, got the mount on e-Bay from some guy in Australia.
Old Sep 16, 2010 | 04:36 AM
Dronac's Avatar
What center console top is that? I want one!
Old Sep 16, 2010 | 04:52 AM
sixty5vdub's Avatar
I like it! This is on my short list of things to buy. I have noticed that some of the gauges are illuminated green, others are blue. Is this an option that can be changed with a setting in the gauge, or just different gauge models?
Anthony
Old Sep 16, 2010 | 09:25 AM
YingYang's Avatar
Its a homemade grab handle.
https://www.jk-forum.com/forums/show...97#post1660197
Old Sep 16, 2010 | 09:26 AM
YingYang's Avatar
Anthony
You choose which color you want. From what I remember the selections are red, blue and green.
Old Sep 16, 2010 | 10:00 AM
htweelz's Avatar
Wow where do you drive where the intake air temp is 65,000 degrees?
Cool gauge by the way.
Old Sep 16, 2010 | 10:08 AM
MikeReo's Avatar
will this give you a transmission temp?
