Viair Super Duty Installation?
Old Sep 16, 2010 | 07:10 AM
GON WHLN's Avatar
Default Viair Super Duty Installation?
I can't find a complete write up on the installation of the Viair dual compressor system.
I heard somethng about putting the compressors behind the tailights in the body gap?
Is there a write up somewhere?
Old Sep 17, 2010 | 02:54 AM
GON WHLN's Avatar
Bump... no one has installed this system?
Old Sep 17, 2010 | 05:08 AM
I purchased a compressor mount that bolts to the two bolts that hold on the break fluid resovoir. It was about $50 shipped. I would think if you mounted it in the body it would be loud as hell. I then relocated the EVAP canister and mounted the 2.5 gal. air tank in it's place. It required a little fab. work, I was able to use one of the bolt hole from the EVAP to bolt the tank, I then needed to drill a hole for the other side. Then I used a steal plate to mount the other end to the body frame. the gage was mounted in the dash just above the drivers side speaker. Quick disconnect hose conection was mounted in the drivers side seat mount, as I didn't want it outside of the vehicle. I can't post any pics right now. If you PM me Ill send some pics over the weekend.
Old Sep 17, 2010 | 05:26 AM
Ghost63's Avatar
I found this thread that has photos of a compressor installed behind the right tailight. Look on the second page of the thread.
https://www.jk-forum.com/forums/show...A-Installation
