Axle shaft swap...Help please
Changing out my ale shaft today... anyone do this and have advise???? Never done this and not sure how yet.
" sorry...the rear axle"
front or rear? either way, it's not too hard to do assuming your front shaft is pre-assembled and the rears have bearing pressed on. up front, you will need a big 36mm socket, 12 pt 13mm wrench and a 21mm for the job and in the rear, you will need an 18mm wrench.
Keep in Mind that the picture above is not a JK those are TJ shafts.
Also if you order Shafts from us they come pre assembled with new ABS tone rings, New Backing Plates , Seals and Bearings . So they are ready to slide in .
David
David
