Bad Wheel Bearings?
Old Sep 17, 2010 | 09:31 PM
betjeep09's Avatar
Default Bad Wheel Bearings?
2008 JK X
38k miles
3 in lift
just added 33's
and turned the rotors and replaced the pads
now i hear a squeaking sound from drivers rear
increases with road speed stops when brakes applied
hit a bump and i hear the squeak brakes or not
havent noticed anything in corners
if so where can i find wheel bearing and how much am i looking at
will replace myself
Old Sep 18, 2010 | 10:24 AM
derby911's Avatar
normally those hubs will growl more than a squeak when they go bad check and make sure you don't have a backing plate touching a rotor
Old Sep 18, 2010 | 01:13 PM
ronjenx's Avatar
Exactly!
Old Sep 18, 2010 | 10:05 PM
betjeep09's Avatar
Will check it out tomorrow. Do JK's have wheel bearings or complete hub assemblys and if they do can they be re built? Also why aren't and commercial part stores able to get many parts that are rather common, when there are so many JK's on the roads these days????
Old Sep 19, 2010 | 05:48 AM
derby911's Avatar
They have hub assemblies and they are not rebuildable. Aftermarket sells hubs for most vehicles so if they don't yet its only a matter of time
Old Sep 19, 2010 | 07:08 AM
ronjenx's Avatar
See this thread about the JK front hub assembly:
https://www.jk-forum.com/forums/show...ighlight=study
Old Sep 19, 2010 | 09:44 AM
captjay's Avatar
the rear has bearings which can be taken out and replaced. these bearings are pressed off and on your axle shaft. if you feel its the bearings, check the wheel for heat and compare to other side. jack up that side and check for play in the wheel up and down side to side. most likely its just your brakes, the rotor since u had it turned, or dust cover. some brake pads just squeal brand new out of the box.
Old Sep 19, 2010 | 01:23 PM
ronjenx's Avatar
Ah, yes. I got derailed by the word hub in the other posts.
Old Sep 19, 2010 | 03:28 PM
captjay's Avatar
i always remember the rear bearings since i have personally blown out the pas side rear.
i was curious why everyone was getting wrapped up on the front hubs when he stated rear
Old Sep 19, 2010 | 04:54 PM
voodoojk's Avatar
i know of numerous jks that do this. Mine included. does it at random. Hit your brakes hard and it will go away. I think its the rear park brake pads but haven't confirmed it yet.
