any tips or tricks to center frnt axle
Old Sep 19, 2010 | 09:57 AM
captjay's Avatar
Default any tips or tricks to center frnt axle
installed JKS adj frnt trackbar. i am about 2 inches over to the pass side. any tips or tricks to get the axle slid back in center??
Old Sep 19, 2010 | 09:58 AM
wayoflife's Avatar
JK-Forum Founder
sure, this write-up should help you out
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Sep 19, 2010 | 09:59 AM
captjay's Avatar
whoa, holy crap u are quick! thanks eddie
Old Sep 19, 2010 | 10:11 AM
captjay's Avatar
ok so i read that.
but, how do i physically move the axle over to to be able to re install the adjusted track bar?
Old Sep 19, 2010 | 10:13 AM
opdsgt's Avatar
Have your wife sit in the Jeep and gently move the steering wheel.
u-joint's Avatar
Originally Posted by captjay
ok so i read that.
I removed my old track bar, then I had my wife get inside the Jeep (with it running) and turn the steering wheel until the Jeep moved left (or right) in relation to the axle
u-joint's Avatar
Dang, you quick
Old Sep 19, 2010 | 10:15 AM
captjay's Avatar
hahahaha i thought u were building up to some kind of joke
great thanks guys, will try it out.
Old Sep 19, 2010 | 10:19 AM
wayoflife's Avatar
JK-Forum Founder
ok so i read that.
this is from step #5
5. Use a crescent wrench to secure the rod end jam nut in place and make sure that you still have both misalignment spacers in place. With the engine off, put your key in the ignition, make sure that the steering wheel is unlocked and then have a friend turn it in one direction or the other until you can line up your adjustable front track bar rod end with the axle mount hole on your Jeep JK Wrangler. Secure the rod end in place using the factory hardware.
Old Sep 19, 2010 | 10:25 AM
captjay's Avatar
wow, ok guess im still little hung over here to have missd that one. thanks again. maybe i will wait a couple more hours
