Show your rear armor
Old Sep 20, 2010 | 08:19 PM
joneszj's Avatar
Thumbs up Show your rear armor
Post up pics of the rear armor skins on the JK. Which ones have the best fit? I've been through enough tail lights and license brackets that it might be time for a change here soon.
Post up the pics.
Old Sep 20, 2010 | 09:52 PM
BIGJ's Avatar
Originally Posted by bubba_zenetti
Smittybilt XRC with swing away tire carrier. Rock Hard jerry can mounts (they bolt right on to the tire carrier) and a Kolpin chainsaw carrier for an ATV I modified to bolt onto the tire carrier. Modified Highlift tube mount brackets hold the jack in place and a set of Pilot driving lamps light things up when going backwards at night. I am going to add a rack to it next.
the hard rocks carriers bolt right on?!?!
great, i been wanting to carry both my gerry cans on mine. here is my SRC rear
Old Sep 21, 2010 | 04:09 AM
westchester's Avatar
Originally Posted by joneszj
Post up pics of the rear armor skins on the JK. Which ones have the best fit? I've been through enough tail lights and license brackets that it might be time for a change here soon. Post up the pics.
I put Warrior Rear Corners on recently, together with their LED light kit. Gets rid of the bulky stock taillight cluster, cost is very reasonable, but took more time than first expected. My license plate is zip-tied on for now, till I get and mount it on a tire carrier.
Old Sep 21, 2010 | 04:38 AM
jeepnick's Avatar
overkill engineering corners and bumper, my favorite so far....
Old Sep 21, 2010 | 06:23 AM
robin's Avatar
overkill engineering looks good!! they could have come up wit better screws.
Old Sep 21, 2010 | 09:25 AM
josh_jacklyn's Avatar
how was the instal on those? do you just use a couple of screws and your done? i was looking into their corners as well as their tail lights. looks pretty good bro
Old Sep 21, 2010 | 09:59 AM
Exclamation
These corners are a very good fit around the JK body and riveted on, so with holes drilled (and the cutting below) they're a permanent fixture. More work than I expected (I figured similar to you) but glad they're on and the overhanging stock taillights are gone.
The lower part of this picture shows the amount of sheetmetal bodywork I chopped out with a sawzall and angle grinder to make space for the LED lights to sit flush and press into the corners, the cuts are'nt pretty but didnt need to be !!
Warrior install instructions are basic, so wiring and adding resistors to slow down the blinkers was trial and error - I can post the wiring specifics for others that get these.
Old Sep 21, 2010 | 12:11 PM
so did you have to cut any on the side of the fenders or you just rivet them in? and the only cutting was to run the tail lights am i getting that right? and how did it make you feel to cut away at your jeep that's the part that i don't know if i can get over yet...
Old Sep 21, 2010 | 01:10 PM
Break out the power tools There is no cutting on the sides. Only cuts to body are extending and opening the tailight hole for the 6" light, and making a new 3" hole for the reverse light, as in the photo.
The JK body's tail area is double skinned, so cut through the red body skin and through the inner primer gray metalwork.
Rivets are included, so drill a couple of holes on the side and rivet the corners in place to finish the job.
Old Sep 21, 2010 | 02:56 PM
joneszj's Avatar
For the overkill corners, how was the install? Does it just use nutserts or however you spell em? Any cutting to the body? Are you happy about retaining the stock taillights?
Do they make these smooth rather than diamond plate? And do you have any pictures looking down from above? Is there a gap between the armor and the body? I can't really tell from the other pics.
Anybody get the poison spyder skins? Or ORE? Are there more kinds that incorporate LED tails that I'm missing?
