TF 2.5 inch lift vs. TF 3 inch coil lift
Old Sep 21, 2010 | 05:50 PM
kwlinder's Avatar
Default TF 2.5 inch lift vs. TF 3 inch coil lift
I have a question which I haven't been able to find searching around. I'm looking to run 35s on my 6 speed 4-dr Rubicon and am looking at both the Teraflex 2.5 inch and 3 inch coil lifts. Other than getting a little but extra clearance with the 3-inch lift, are there any real impacts by going with the extra half inch of lift (such as needing adj. control arms, upgrading driveshafts, etc.).
Old Sep 21, 2010 | 06:39 PM
Pluke the 2's Avatar
I normally don't suggest running a 3" especially TF suspension on a two door because they actually give you more than the advertised height. But on a four door 4" in height looks right (thats what you can expect from a TF 3" on a four door)... Having said that, a four door's drive shafts are stronger and at a lesser angle at which a two door is set up at. So they are stronger and because you have a manual you don't have to worry about your front drive shaft as that is more of a common problem with automatics.
On any suspension lift that net's over 3"+ its recommended that you run control arms and adjustable trackbars to adjust for geometry changes that was altered during the course of the install.
A two door on 35's and 3" of lift looks like this:
you want to be taller!
Old Sep 22, 2010 | 05:21 AM
kwlinder's Avatar
Thanks for the info. I'm definitely leaning to the 3-inch for a little more clearance. Out of curiosity, at what height for a 4-door with a 6 speed do the driveshafts start becoming an issue?
Old Sep 22, 2010 | 05:58 AM
wayoflife's Avatar
JK-Forum Founder
first off, you need to know that the teraflex 3" lift will in reality give you closer to 4" of lift. being that you have a 6 speed and an unlimited, you will not need to get new drive shafts front or rear but you may find that a set of adjustable front lower control arms are a nice addition as they will allow you to add a bit more caster. also, if the kit you get doesn't already come with it, i would recommend getting adjustable front and rear track bars so that you can recenter your axles. aside from that, you should be good to go.
Old Sep 22, 2010 | 06:08 PM
kwlinder's Avatar
Thanks WOL.
Right now I'm leaning towards the 3-inch TF lift and will definitely be looking at getting adjustable track bars and adjustable front lower control arms. With the 3-inch TF lift would there be any additional benefit from going with a full set adjustable control arms all the way around as opposed to just the front LCAs
Old Sep 22, 2010 | 06:22 PM
Thanks WOL.
Sure. More adjust-ability means you can dial in your Jeeps suspension to compensate for geometry changes..
