Cold Ait Intake Using factory air box for $40
Old Sep 26, 2010 | 05:44 AM
rhettley's Avatar
Default Cold Ait Intake Using factory air box for $40
I made a cold air intake out of the factory box and a filter from a local parts store. Works great.....looks and works just as good as the aftermarket kits.
I think I spent $40 total and about an hour fabing in up.
Anyone interested in the details and some pics?
Old Sep 26, 2010 | 05:51 AM
SilverShift's Avatar
YES!
Old Sep 26, 2010 | 07:04 AM
rhettley's Avatar
Default Pics
Here you can see the setup. By removing the stock air box. I was able to cut off the top and sides leaving a wall in the back to block the heat from the radiator.
I utilized the stock mounts on the air box to mount it to the Jeep. I bought the air filter and tube from a local parts store. I used two screws to secure the tube to the old stock box.
All told it took about an hour to make. Looks pretty clean and works great!
ID:	90865   Click image for larger version
Old Nov 4, 2010 | 09:29 AM
JDScott10's Avatar
Good idea...disapponting outcome. The filter looks smaller than the factory, and without any sort of dam, you're asking for a hydrolock.
Dry climate, may work out, but I'd rather stick with opening the top of the factory box and using pipe insulation.
Old Nov 4, 2010 | 09:32 AM
ronjenx's Avatar
How does the cold air get to the intake?
