check this out!
Old Sep 26, 2010 | 03:22 PM
jeeperjkjeeper's Avatar
Default check this out!
i took my stock Rubi rails off today to spray behind them with rocker guard but decided it wasn't necessary.
Anyways while i had them removed i figured i would give them a good cleaning and spray the inside with rust check.
When i removed the first end cap i could not believe the amount of rust that had accumulated in a matter of two years.
i shook all the loose rust out and soaked the inside with a rust preventer/oil spray. Hopefully this halts the corrosion process.
I also soaked the corroded metal found when i removed my console for line-x.
ID:	91014   Click image for larger version
ID:	91015   Click image for larger version
ID:	91016   Click image for larger version
Old Sep 26, 2010 | 05:37 PM
WranglerJoe's Avatar
There is a JK 4 door Rubi. in the parking garage at the hospital I work at and his rails are friggin' rusted ALL OVER them!!! the whole outside is rusted BAAAAD!!! hope the frame doesn't do the same. Had my frame Zeibarted when it was new. Just about ready for a touchup b4 winter
Old Sep 26, 2010 | 05:42 PM
Serg5000's Avatar
With all the water and moisture I'm not surprised.
