Gear, Ring and Pinion
hello evey one,
I have a 4 door Jeep JK Sahara AUTO trans., will install the hemi 6.1 engine very soon.
Currently Running a 33" wheels
what Gear Ratio should I go with this set up to change the ring and pinion ?
many thanks in advanced.
Really with the 6.1 even 3.21 ratio would be ok. But your best ratio with that would be 4.10.
I would just run what ever ratio you have, not even worth changing gears with only 33's.
