Removing MORE 1" BL
JK-Forum Founder
you will need to reinstall the factory rubber isolators that you removed if you want to go back to stock. look around or ask in the wanted section and i'm sure you'll be able to find some.
Are these for the front two mounts? Will the longer bolts be ok or will they bottom out?
I have a 2.5" coil lift with 1" spacers on the coils. I've been thinking about dropping the 1" body lift.
I've put a couple different BL's on JK's and I'm having a hard time remembering what exactly I took off to put the MORE on
If anyone is close enough to come over, we can do a swap in my driveway! My BL for your stock bolts,etc. I'm still not sure if I'm taking it off though.
you should be able to search for instructions and go in reverse. i think there is write up on this exact BL. good luck and let me know if you decide to sell!
