Lift installed with new 35's
I installed the Teraflex 2.5" w/shock extensions and love the result. I found the ride home on the new tires a bit rough compared to what I was expecting. They are inflated to 40 psi. BFG All-Terrain T/A 315-70-R17 I also hear a (hate to say it this what but it's accurate) a "tinkle" or something like a bell at the passenger rear while at low speeds. I have re-torqued everything and it appears fine. Sound was not there before. So..any ideas on the sound and what tire pressures are ya'll running on yours? Thanks everyone!
yep, make sure the brake line extensions are installed properly..had an issue with mine and turned out to be a brake line rubbing the inside of my tire flipped it around..no more clink.
Forgot to say that...I am running Spidertrax 1.5" spacers all around. I have not seen any clearance issue yet. I have not had the time to flex it any though. Will get back under it now and see. Thanks
