2.5 Rock Krawler lift, now have a flighty feel when driving.
Last week I installed the rock krawler 2.5 stock mod lift, with a set of Bilstein 5100 shocks. I took the JK to the alignment shop and they were able to adjust everything within speck except the caster. They said I need a spacer kit. My question is would this improve the flighty feel. The suspension is stiff (not to happy with it) also I don't feel as comfortable on rutty roads, the tires seems to want to climb left to right more than they did before.
Thanks. Mickey
Thanks. Mickey
Please dont put cam bolts on your jeep you will regret it. I am guessing when they say spacer they mean cam bolts.
Save up and get a set of front lower adjustable control arms
David
David
I have cam bolts too.. Granted LCA's are better but if your in a bind( driving to atl from nola for your wedding and can't get on the highway bc of deathwobble) they are not as horrible as everyone says. I have had mine for 2 years with no issues whatsoever and they have never loosened, shifted etc. and I know they have taken some hits( lca mounts are beat up)
JK-Forum Founder
It's actually really easy to do with a Teraflex cam bolt eliminator kit.
If you can get MINIMUM 3deg positive caster with cam bolts, then you will be ok for now. If not then don't waste your time or money, you HAVE to get adjustable control arms. If your alignment shop says you are in negative-1 degree right now and your rig feels really flighty, then you no doubt need arms. I recommend 5 deg of caster once you can adjust it that much.
Let me get this straight all I need is new front lower control arms, then have another alignment done. It drives ok, I just want it driving like it was when stock. Seem like it just not as stable and it could be because of stiffer suspension. I wish I had got a different shock, the 5100 are too stiff for my taste. I did my research and some said that they road better than stock, I just don't feel it. You can feel every dip and rise in road the jeep rocks from side to side so much that my back was hurting after a hour.
