Why has my Procal stopped working?
Went to change tire pressure threshold today and got no horn beep when I attached the Procal to the OBD2 port. Then tried reseting to stock and no beep again. Tried all key positions too. Any ideas?
Might wanna call aev, see what they say, that's a new on on me. Have you tried disconnecting battery a few, the try it again? These electronics are funky on the jk.
funny, mine did the same thing yesterday. i was getting code 37 and then after plugging and unpluggin a few times, it magically worked again. i was simply trying to use the extended idle.
Not thinking this will work but sometimes when the program drops (I swear it's happened) I reset the program to stock (even though you don't hear the horn in your case) and then disconnect the battery. Wait 10 minutes. Reconnect and reattempt to program. If nothing else you've reset things and are starting from scratch. Try something simple at first like the TPMS reset. It's something you can easily verify (lower psi in tires to below factory) and the indicator light should not come on. If it does then you know it's not working. Could be a damaged programmer and in any case should be covered.
