Your opinions on these 2.5" lift kits???
Old Nov 25, 2010 | 04:10 PM
20JK10's Avatar
Default Your opinions on these 2.5" lift kits???
I'm just looking for your opinion on these 2.5" lift kits. I know a lot of you will say go with a 3" lift. The reason why I am looking at the 2.5" kits is mostly do to money, or lack of it. I don't have the money to drop on a good 3" kit, 35" tires/wheels and new gears. And after analyzing the type of wheeling I do, a 2.5" is more than adequate [blasphemy, I know]. Now, if i lived near Moab or Rubicon, a 3" kit wouldn't even be a thought.
Is the kit worth the price for the parts that come in it?
Quality of the parts in the kit?
How did the springs change the ride, positive or negative?
Would you recommend the kit?
Rock Krawler
2.5" Stock Mod Coil Suspension System
Front adjustable track bar, rear track bar relocation bracket
RKSJK25000 / $399.99
4wd.com/productdetails.aspx?partID=60161
2.5" Max Travel Coil Suspension System w/o shocks
Adjustable lower control arms, adjustable front track bar, rear track
RKSJK25001 / $999.99
4wd.com/productdetails.aspx?partID=60162
Skyjacker
2.5" Value Flex Coil Suspension System w/o shocks
Fixed lower control arms, rear track bar brace
SKYJK2501KCR / $760.98
4wd.com/productdetails.aspx?partID=56302
2.5" Coil Suspension System w/o shocks
Rear track bar brace
SKYJK250BK / $374.97
4wd.com/productdetails.aspx?partID=42792
Teraflex
2.5" Coil Suspension System w/shocks
TER1251002 / $664.99
4wd.com/productdetails.aspx?partID=59619
2.5" Coil Suspension Sustem w/o shocks
TER1251002 / $421.99
Old Nov 25, 2010 | 04:31 PM
JeepNDad's Avatar
I would go with the 2.5 TeraFlex and definitely call David at Northridge 4x4. He will hook you up with a great deal.
http://www.northridge4x4.com/
Old Nov 25, 2010 | 04:37 PM
Rainier's Avatar
Default My vote
I didn't see OME on your list but having run this lift for about 1,500 miles it takes my vote. It's an advertised 2'' lift however you will get closer to 3'' and quality ride. Get the kit from Northridge that includes adj track bars. Otherwise i hear good things about Teraflex
Old Nov 25, 2010 | 05:51 PM
07JKRUBI's Avatar
If you have plans in the future to upgrade, I would say go with the Rock Krawler. That way you can upgrade as $ allows....
Old Nov 25, 2010 | 05:56 PM
gijeep's Avatar
ID:	104983Click image for larger version
ID:	104984Click image for larger version
ID:	104985Click image for larger version
Procomp 2.5 very beefy rear mount, new shocks and springs and bumpstops...
Old Nov 25, 2010 | 06:07 PM
jeepmedic's Avatar
I vote OME. I @ about 20K on mine, no sagging, netted 3.5" lift on HD coils, and awesome ride !!
ditto on the Northridge kit.
Old Nov 25, 2010 | 06:12 PM
Jollydodger's Avatar
x2
OME super nice ride on and off road.
Old Nov 25, 2010 | 06:40 PM
Luckdog's Avatar
Not to hijack the thread, but hopefully this will also interest the op. If the OME gives close to 3.5" lift, does it not cause driveshaft angle issues?
Old Nov 25, 2010 | 06:43 PM
randyd's Avatar
I have 45,000 miles on the TF 2.5 coil life. Which gives you a good 3 inches of lift. I have a rubi unlimted. I stayed with the stock shocks and did the extentions as I was told the rubi shock are great. So far not one problem...
Oh and the wheel spacers as I'm still running the stock size tires and rims..
Old Nov 25, 2010 | 06:56 PM
nthinuf's Avatar
OME makes 5 different coils for the JK, and all are probably sold in the box that says 2". The above posts are referring only to the HD version, which are known to give 3-4". You can dig up posts on this site saying that the TF 2.5" coils give 3-4" of lift also. Just depends.
There are a lot of variables involved in the issues with driveshafts. It is better to get an idea of the entire setup, rather than make a blanket statement that anyone will need shafts at xxx height...
