wider wheels and driving
What kind of effect does having a wider stance create on driving? I mean, with wider wheels with more backspace or wheel spacers. No lift though. And only slightly bigger tires then stock Rubi. I have been told the wider offset makes a more numb feel to the steering wheel and squirrely.
I would think that the squirlly feel would depend a lot on the tread design and overall width of the tire. I have an 07 unlimited, with Dick Cepek FC ii 12.50 x 33 x 17 radials with DC-1 9 inch wheels, 2 inch over coil spacer lift and no wheel spacers. I think that the stability is actually better than the original Dueler tires that were on the vehicle with the exception that with the wider tire there seems to be a more severe pull when one side or the other hits standing water on the road at higher speeds (50-65).
Hope this helps you.
I went from stock, to tires protruding beyond the flares about 2 inches, and it's a bit squirelly. Im not sure if it's from the more aggressive tires, the stance, or the fact that I'm no longer driving on horribly toed in tires. I imagine wide = stable though.
went from stock to wide stance and wide tires. The wide tires want to follow the groves in the road more, and the wide stance means I don't really fit into those groves anymore. I wouldn't say squirrley, but I have to pay more attention to the road and steer more than before.
Not that big of a deal
I'm running some 33" Bridgstone Revos w/ a 4.5" bs wheel. Although not a lot different, I feel it's a bit more stable. Better tires and a little wider stance will do that. A lot has to do with how much air you run as well as to how it will react to the road.
Wider is better.
The only down side I can think of is premature ball joint failure. But thats on the extream side. You would probably never have an issue.
My jeep has 3.7 bs on a 10'' wheel and no problems.
