Painting your AXLES & CHASSIS
Old Nov 28, 2010 | 11:09 AM
RN M OVR's Avatar
Default Painting your AXLES & CHASSIS
Aside from having paint flake off my differential covers and the actual axle housing, I have noticed quite a few members on here who have welded brackets and braces onto their axles and/or chassis, and have painted over them to match just about perfectly with the OEM color of their axles and/or chassis.
Question:
What paint are you using to match? What's the process you are taking to have the paint stick and not flake off?
Old Nov 28, 2010 | 11:15 AM
mkjeep's Avatar
I used 3m Rubberized under coating, I just pressure washed it the day before. Sticks really good. I just re-did my innner fenderwells(no liners on rear) I did over a year ago and went ahead and did the axles and other components/frame.
Old Nov 28, 2010 | 11:44 AM
RN M OVR's Avatar
Thanks for the quick response. I'll definitely look into that. If you can and don't mind, post a pick of your axles and/or frame so I can get a look?
Old Nov 28, 2010 | 12:20 PM
Venom19's Avatar
Lots of great stuff here.
.eastwood.com/specialty-coatings/chassis-frame-paints.html[/url]
Old Nov 28, 2010 | 01:16 PM
mkjeep's Avatar
Been painted about a month now, pressure washed off at least 3 times since then.
Name:	frame pics 011.jpg
ID:	105460Click image for larger version
Name:	frame pics 009.jpg
ID:	105461Click image for larger version
Name:	frame pics 008.jpg
Old Nov 28, 2010 | 03:22 PM
RN M OVR's Avatar
Thank you both so much.
Old Nov 28, 2010 | 04:08 PM
RN M OVR's Avatar
Default Which one should I purchase?
Quick Question:
Which one should I purchase? And, how much of it?
Thanks
/solutions.3m.com/wps/portal/3M/en_US/Marine/Home/Products/Catalog/?PC_7_RJH9U5230GE3E02LECIE20S4K7_nid=6Z84PL497ZbeQ H8HT14PGTgl[/url]
Old Nov 28, 2010 | 04:17 PM
mkjeep's Avatar
I use the 3m professional grade rubberized( black and orange can). I used 4 cans for what I do, so if you get a case, you should be good.
Old Nov 28, 2010 | 04:36 PM
JKlad's Avatar
Wondering what prep you need to do first? Painting this stuff is something I should have done the day I drove it off the lot when everything was fresh and unblemished. Two years on all the unpainted cast stuff (driveshafts, u-joints, tie rods, steering knuckles, steering box, etc) are coated in a layer of orange rust.
Obviously a wire brush to start, but then a coat of rust-inhibiting zinc unercoat first?
Old Nov 28, 2010 | 05:19 PM
lowrpmtork's Avatar
por 15. And you'll never have to touch it again.
