Stock Carrier Help!
Not sure if this is the right location for this, but here goes!
I have yet to get a proper spare tire (still rockin' the stocker)
I have decided to go ahead and buy it. The thing is, how well will my stock tire carrier hold up to a 35x11.50 duratrac? i don't want to bend the tailgate...
I know i'm taking a risk by doing this, i'm saving for a tire carrier now tho.
Opinions and solutions would be awesome
thanks guys!
thanks guys!
fairly sure that if you roll with the 35 you will break/crack the plastic. I have a 36 and fairly heavy wheel. I was TOLD to not use the stock carrier by the local shop. I have a full spare but removed the stock carrier housing all together.
I think a lot of people, including myself, use the stock tailgate tire carrier for larger tires....if at least for a temproary solution. I haven't had any problems with it thus far. My tires are heavy...35x12.5" Toyo MT's. By choice I would have a bumper with a tire carrier on it though, but can't afford it right now....soon.
I would just check it every once in a while to make sure there are no cracks or damage or anything like that.
I would just check it every once in a while to make sure there are no cracks or damage or anything like that.Trending Topics
I tried using the stock carrier for my 35x12.5r17 KM2 and wasn't comfortable with the amount of rattle and movement I was getting from it. I've been driving with the spare in the back of the Jeep for a couple of weeks. Getting the OR-Fab tire carrier installed today.
I figured spending the money on a tire carrier now is a lot less than having to buy a new tailgate + carrier later.
My 255/85/16 BFG MT (33.1") is mounted on the stock tailgate with no probs at all. That said, 33 has got to be the tallest tyre you can use before you need to extend or replace your third brake light...My 33" fits perfectly but anything higher would obscure it.
