best lift for jk?
Old Nov 28, 2010 | 09:27 PM
bluesteeljeep's Avatar
Default best lift for jk?
best lift for jk around the 1200 range to run 35's on?
Old Nov 28, 2010 | 09:31 PM
Abacabb's Avatar
Check out the Teraflex 2.5" Performance Budget Boost.
You'll clear 35s and have some money leftover for other mods.
Old Nov 28, 2010 | 10:08 PM
vandegrift's Avatar
Or add a $1000 and go with the full control arm kit from Tera Flex and always be happy, that's what I did.
Old Nov 28, 2010 | 10:32 PM
nthinuf's Avatar
Define "Best"
A vague post giving no idea what your goals are isn't the best start...
Have you opened the FAQ's yet? Lots of good info to start basing some decisions on. Note the areas that give recommendations on which components you will want for various lift heights. And driveshaft recommendations. And caster recommendations. And gearing recommendations.
Spend a little time reading, then come back and ask the new questions you come up with.
Old Nov 28, 2010 | 10:36 PM
BigBruce's Avatar
Definitely need to know what you want to do with your rig to know what would be best.. Lots of options for Jeeps, especially the JK model!
Old Nov 29, 2010 | 04:06 PM
h1ker's Avatar
Do it right the first time, dont do somthing and say later "thats what I should have done. I went with a OME HD lift and am extremely happy with it. check it out northridge 4x4 is runing a special on it I think.
Old Nov 29, 2010 | 04:15 PM
angermgmt's Avatar
Depends on budget as well
Old Nov 29, 2010 | 04:46 PM
RAZDJK09's Avatar
I can speak for ROCK KRAWLER. 3.5" great lift for on and off road. Get good shocks though.
Old Nov 29, 2010 | 05:03 PM
Full-Traction Suspension's Avatar
Former Member
Check out our Premium plus kit, its what you need for a 3" lift kit. Its made in Bakersfield, CA
Maintenance and noise free!!!!!
Northridge4x4 has these in stock
http://www.full-traction.com/detail....TID=492&NOTES=
Old Nov 29, 2010 | 05:20 PM
Crasher's Avatar
[ I went with a OME HD lift and am extremely happy with it. check it out northridge 4x4 is runing a special on it I think.[/QUOTE]
X2. This lift is complete with the best components from several companies. everything you need and nothing you don't. Call and talk to David and get his opinion on which lift is right for you.
