Metal on Metal contact, what to do to prevent corrosion?
Old Nov 29, 2010 | 02:20 PM
muddenjeep's Avatar
Default Metal on Metal contact, what to do to prevent corrosion?
Putting on windsheild light mounts, but don't feel good about metal on metal contact. Looking for a good product to help prevent corrosion. Any review on products not to use or any recommendations?
Old Nov 29, 2010 | 02:29 PM
shockwaveaz's Avatar
What brackets are you using? Are they powder coated?
Sent from my EVO using Tapatalk.
Old Nov 29, 2010 | 02:34 PM
muddenjeep's Avatar
The mounts are MBRP inc. they are powder coated.
Old Nov 29, 2010 | 02:39 PM
Msrunner's Avatar
Zep Iron Clad. Tranparent Film, inhibits rust, protects for years. Provides an impenetrable barrier. Good stuff. I have used it in salt water environment W/ good results.
Old Nov 29, 2010 | 02:51 PM
Tiburon's Avatar
I cut out a piece of rubber from an inner tube and used it like a gasket.
Old Nov 29, 2010 | 03:25 PM
Harbourone's Avatar
Same, had an old dirtbike tube laying around so I traced the bracket and made a gasket out of it.
Old Nov 29, 2010 | 03:47 PM
nofr13's Avatar
light coating of grease works wonderful. wheel bearing or marine.
Old Nov 29, 2010 | 04:26 PM
ARM2004's Avatar
Hardware stores sell thin rubber washers.
Old Nov 29, 2010 | 05:45 PM
mjturner1105's Avatar
x2 on the rubber washers thats what i used were neoprene washers 5/16 inner 3/4 outer and 1/8 thick cost me like 15 cents each
