question about wheels and tires....rockstars with toyos
vehicle - 2011 JK unlimted (stock tire is 255/75/17)
Can I fit the 18x9 Rockstar KMC XD (0 offset and 5" backspacing)
Wouldl ike Toyo MT's (255 or 265)
Stock jeep and don't want lift or spacers on there. IS this set up possible? Does anyone have pics of this setup on their jeep???
Thanks
Thanks
Kind of off topic, but Id be careful with Toyo MT's. When I was a mechanic, we wouldn't install them on an aluminum rim because their beads and rim protectors are so stiff they will wear out the bead seat on the rim. I have experienced this personally with my welding truck, an 08 ford f-150 with 33x12.5 17's and when I changed my tires after 55,000km the bead seat on the stock ford rims were worn and they would not reuse the rim. And when your spending that money on rockstars I'd look at a different tire. I run the Toyo AT with 285/70 17 with no lift or spacers and I have very minor rubbing at full lock on the sway bar so I think 265 or 275 you would have zero issues
I am running the 17 inch rockstars with the 33x12.5R17 with no backspace or lift
i only have rub when i back up but going forward full motion .. One thing i should warn
this weekend I went playing the the snow and while climbing a hill the passager side tire went up thou my fender..not impressed so it will work but a lift is recomended
You should be able to run the 18s, but as said above, you are going to need at least a 12.50 width tire on a 9" rim. If you go 33 12:50 18 you should be good. My good friend is running that same setup with just a 1" spacer in front to level it out.
