2.5 coil lift install hiccup
Old Dec 6, 2010 | 10:48 PM
asuperhero's Avatar
Default 2.5 coil lift install hiccup
so i tried to install my TF 2.5 coil lift on sunday, but i got stuck, and had to back track and put everything back together.
i took the tires off, easy.
i was trying to take the front sway bar links off, but i couldn't get either side to budge. i haven't used any WD-40 yet, cuz i was out at the time, but from the write-ups and research i was doing, it didn't seem like anyone else had the problems i came across.
i've read all the write ups very thouroghly and i iaven't found anything.
any insight for me? busted a socket wrench, and i almost busted another one. friend and i both tried, and we both failed. i could use some help with the install if anyone is around the seattle area and has a garage. my dad's tools are pretty limited, and my apartment garage is too small, nor do i have the right tools for the job. i'll provide the beer, and bring over a pizza or something along with some helping hands. any sort of help will be greatly appreciated!!
Old Dec 6, 2010 | 10:53 PM
nthinuf's Avatar
PB Blaster
Spray all the bolts the night before. If they are really stuck, spray for two nights before the install. A little heat may help also.
And grab a breaker bar if you don't already have one. The extra leverage comes in handy.
Old Dec 6, 2010 | 11:02 PM
PG-JKU's Avatar
X2 on the PB Blaster or Liquid Wrench. When I did my front swaybar discos I had to grab the bumper and push with my feet on the wrench as hard as I could to get the bolts loose.
Old Dec 7, 2010 | 01:50 AM
Cunnart's Avatar
Originally Posted by FFA_nsk
this is why i just pay someone to do it
BOOO!
Try the lubricating spray. If that doesn't work swing by a shop and ask them to loosen the nuts and offer the mechanic a few bucks for his time. Other then that you need more leverage, like a breaker bar. Sorry I have to ask, you were turning it the correct way?
Old Dec 7, 2010 | 03:31 AM
wazooz2424's Avatar
Try a breaker bar. A floor jack handle or hilift handle works well
Old Dec 7, 2010 | 03:58 AM
jlarso's Avatar
Default Penetrating Oil
A half and half mixture of automatic transmission fluid and diesel fuel makes a wonderful penetrating oil, far superior to PB blaster, in fact nothing commercial beats it.
Old Dec 7, 2010 | 04:25 AM
ccwbrd's Avatar
No one has an impact gun? works everytime!
Old Dec 7, 2010 | 05:37 AM
daubie's Avatar
Default Impact
I used an impact on mine. It was the only thing that would take them off. Unfortunately it snapped one of the rear ones that I was supposed to move up front. No big deal, just gave me an excuse to get two new ones for the front
Old Dec 7, 2010 | 05:42 AM
wayoflife's Avatar
JK-Forum Founder
as mentioned, a breaker bar will do the trick.
Old Dec 7, 2010 | 08:40 AM
wallawallaron's Avatar
Might try a post in the Northwest club section for help..Lot of members on the west side. Good luck..
