lift questions
Old Jan 5, 2011 | 07:46 AM
erol1991's Avatar
Default lift questions
hey i was just wondering i went into a jeep store and he told me if i bought a 700 lift kits im going to need a whole bunch of other things i will need to eventually buy.
what else do i need other then the coils and please dont just say steering stabilizer, can you guys let me know what that part does
cheer
ive beeen looking everywhere for this
Old Jan 5, 2011 | 07:48 AM
erol1991's Avatar
oh and i have a 1 inch coil spacer in the front to fix the factory dip
Old Jan 5, 2011 | 08:03 AM
PagosaGlen's Avatar
What lift height and brand of lift are you looking at?
Old Jan 5, 2011 | 08:10 AM
wayoflife's Avatar
JK-Forum Founder
cheer
first rule of thumb, don't ask advice from a jeep store as their whole job is to get you to spend more money with them. to answer your question, i think you need to first ask how big of a tire do you want to run and what kind of trails are you hoping to play on. we can go from there
Old Jan 5, 2011 | 08:23 AM
rdubb1031's Avatar
This forum will give you much more honest answers you just have to look for them. I put on a 2.5" Teraflex coil/shocks lift. I kept the stock wheels, but put on 295/70R18 Nitto Trail Grapplers which equate out to 34.6" x 11.5" tires. This required me to get wheel spacers and find another way to mount my spare tire to my tailgate. After 4 months on a MBRP relocation bracket I popped a weld in my tailgate and it was rattling.
Also, you really shouldn't need to pay for an install. Ask around on the forum and get some help, Thats what I did.
Give more specifics on the tire size and off-roading desires and you'll get plenty of input on what you need.
Old Jan 5, 2011 | 03:50 PM
nthinuf's Avatar
Stickied to the top of this modified area are some FAQ's. In the suspension area, you will find some good info on recommended components.
Your best bet is to do a little research and figure out what all of the different components do so that you can decide which you will need, which you will want, but can wait on, and which you can do without. But as the others said, a lot depends on your budget and the actual lift height.
Old Jan 6, 2011 | 10:50 PM
erol1991's Avatar
thanks everyone.
Rubicon Express JK 3.5in Standard Kit 4-Door is the lift kit
http://www.northridge4x4.com/proddet...p?prod=RE-7142
thats the link
im planning on running 35s eventually i know i need to change my gear ratio but other then that what else do i need with that lift, i have 1.5 inch spacers but im talking about like steering stabilzers and other things like that
thanks much appreciated
Old Jan 7, 2011 | 03:47 AM
Rhino64's Avatar
IMO not the best lift for you. You don't need 3 1/2" lift to run 35" cam bolts will cause you nothing but problems. If you want to go 3 1/2" do a 2 1/2" lift with a 1" body lift. BTW if you have a auto you run the risk of tearing the boot on your front drive shaft with a 3 1/2" lift. To get the full benefit of any lift you're gonna need sway bar disconnect also.
Old Jan 7, 2011 | 08:03 AM
erol1991's Avatar
how how about the RC 2.5 coil
http://www.roughcountry.com/jeep_jk_2perf.html
would i need sway bar disconnets and what is that btw
Old Jan 7, 2011 | 09:32 AM
sum-daze's Avatar
Take a look at this one
http://www.roughcountry.com/jeep_jk_3-seriesII.html
This is the one I went with and love it, comes with spacers for the skid plate so you don't tear your drive shaft boot and no cam bolts. You may want to get the Dual Steering Stabilizer also. Just my 2 cents.
