Removing Front Bumper Bolts
Ok... other than tires, tonight is my first real mod... XHD Front Bumper... those 8 bolts that hold the stock front bumper on are killing me... my Jeep is a 2008 so the bolts have had some time to get "locked on" pretty good... I sprayed them with WD-40 and I'm heading to Home Depot in a bit... going to get a deep 18mm socket... any other suggestions? THANK YOU!
BTW 'PB Blaster' is much better for pre-treating bolts then WD-40. Stinks all to he!!, but works like a champ.
Use a long handle rachet, use a 15mm socket to remove the bumper cover(thats the two outer bolts).... Its easier to remove the cover if you have the hooks. Remember there is a solid metal bumper under the cover. Also unplug the fog lights first.
Good luck.
Good luck.
Get a long breaker bar or 14-18" tube to slip on the end of your ratchet to act as a helper. there isn't much room so you need lots of leverage, once it's loose you're golden.
First I would remove the grill, then remove the plastic piece that sits between the bumper and the grill. This piece is held on with these plastic push piece, I had to use two flat head to pry them up. There are two, one on each side, almost directly under the turn signals. Once you remove this piece you will have better access to the 4 inner bolts ( 2 on each side).
Also remember to remove the splash guard to get to the fog lights. There are like I think 8 total push piece. 6 connected to the bumper and 2 that are connected the the frame. I am not sure about the amount connected to the bumper but I know there are 2 connected to the frame.
x2 and the PB blaster. Works great.
PB blaster is better than moms spit and 409 combined...I bout it once in a pinch because that is all the place had. I will never settle for anything less anymore. The stuff is truly amazing.
lol
