Warrior Adventure Rack
Old Jan 5, 2011 | 03:01 PM
LnL1003's Avatar
Default Warrior Adventure Rack
Trying to find out more info on the Warrior Adventure Rack. Anyone has this installed? Looking for pros and cons.
Looking for a tailgate rack to use with stock bumper. This seems to fit my needs.
http://www.warriorproducts.com/catalog/07-10-jeep-wrangler-jk/rack-systems/rear-corners-2-2/
Last edited by Robar; Jan 6, 2011 at 09:09 AM. Reason: PLEASE DO NOT POST CLICKABLE NON SPONSOR LINKS
Old Jan 5, 2011 | 03:07 PM
crazyhorse02's Avatar
I like the look of that rack a lot. Any owners chime in. I wonder how it mounts?
Old Jan 5, 2011 | 03:10 PM
LnL1003's Avatar
Yes me too. I emailed them asking for mounting instructions.
I'll update if I get a reply email.
Old Jan 6, 2011 | 07:23 AM
LnL1003's Avatar
Got a reply from, Warrior. They sent me a word document with the installation. Looks pretty straight forward.
SUBJECT: P/N 831 - 07-09 Wrangler Adventure Rack Installation Instructions
IMPORTANT: Warranty and weight ratings are not valid unless installed with 920 series tailgate cover. We recommend the S920-1 version for most applications.
KIT CONTENTS:
Description
Qty
Description
Qty
Installation Sheet
1
Passenger Side Leg
1
Cargo Basket
1
8mm x 75mm Bolt
2
Driver Side Leg
1
5/16 x 2½” NC Allen Head Bolt
2
5/16” Flat Washer
4
5/16” Lock Washer
2
5/16” NC Hex Nuts
2
3/8 x 2” NC Hex Bolt
4
3/8” NC Hex Nuts
4
3/8” Lock Washer
4
3/8” Flat Washer
8
3/8” Wing Nut
2
Gas Can Clamp
2
PHASE 1: LEG INSTALLATION
1. Remove spare tire from the rear of the tailgate.
2. Remove the plastic covers from the tailgate hinges; to do this you must open the tailgate, pinch the tabs on the inside of the hinge, and then slide them toward the driver side. If you wish to re-attach these, you will have to notch them to clear your Adventure Rack. Be careful that you don’t cut the cover into two pieces when notching.
3. On the driver side of the tailgate, measure mark, and drill 5/16” holes ½” from the left of the tailgate both 1” from the top and bottom of the tailgate, so that the hole spread ends up at 14½”. Use the two supplied 5/16” button head Allen bolt with flat washers and nuts to attach the driver side leg to these holes. The head of the bolt will be on the inside edge so as not to damage the weather stripping. See Fig. B
4. On the passenger side, unbolt the outermost bolts from the upper and lower hinge. Use the two 8mm supplied and two 5/16” flat washers to bolt the passenger side leg into the existing hinge mounting holes that you just removed the factory bolts from.
5. If you chose to notch your plastic covers to fit, now is the time to mark and cut the notches, then you will need to remove the passenger leg, attach the covers, and re-attach the leg.
PHASE 2: BASKET INSTALLATION
1. Place the basket on top of the legs lining the holes in the basket with the holes in the leg’s mounting plates. Use four 3/8” bolts with flat and lock washers to attach the rack to the legs.
2. Finish by placing the gas can clamps on the studs atop the basket, and secure using the two supplied wing nuts.
Tighten all bolts and check to be sure the rack is securely attached to the rear of the vehicle. A 50lb. Weight limit is advised. ENJOY YOUR NEW RACK!
Any owners with this rack want to chime in?
Thanks.
Old Feb 6, 2011 | 07:08 PM
fm3fm3's Avatar
I had one on my jeep for a couple of years. But i took it off about 6 months ago. It worked great but once I upgraded my stock tire and wheel package to steel wheels and 33s it was too much for my stock spare tire carrier to hold so I went with the ORFAB tire and Jerry can holder. The adventure rack would not fit on there too. You definitely need the steel plate for the tailgate as the stock sheet metal it way too thin to support the rack. The installation is pretty simple. As long as you don't mind drilling a few holes in you tailgate. Since I don't need mine anymore I'll sell it to you if you want.
Old Feb 6, 2011 | 07:11 PM
fm3fm3's Avatar
Here are some pic of it when it was still installed.
ID:	125193   Click image for larger version
ID:	125194   Click image for larger version
ID:	125195   Click image for larger version
Old Mar 23, 2011 | 08:40 AM
RustyShovel's Avatar
Default 50 Pound Weight Limit?
It advises no more than 50 pounds? Yet the product shows two jerry cans. A single jerry can full of fuel weighs about 50 pounds.
What gives?
