TeraFlex 2.5 lift with shocks/springs
Old Jan 8, 2011 | 07:08 PM
TonyJeep75's Avatar
Default TeraFlex 2.5 lift with shocks/springs
Hey Folks,
I'm installing my lift but I'm having a problem with the track bar bracket. The track bar wont fit into the bracket. How can I get it to spread open with out buying yet another tool! lol
Thanks
Old Jan 8, 2011 | 07:13 PM
sa29560's Avatar
Pry bar, some KY and a little aggression
Old Jan 8, 2011 | 07:15 PM
Ab1's Avatar
Ab1
Take it out to dinner first!
Old Jan 8, 2011 | 07:16 PM
TonyJeep75's Avatar
I'm gonna take it to prom and give it wine coolers.
Old Jan 8, 2011 | 07:18 PM
bobbyspaghetti's Avatar
Default A crowbar
If I am hearing you right your saying the frame side relocation bracket's track bar opening is too narrow for the trackbar? If I remember right this may have been the case for mine as well. A pin-bar,crow-bar, piece of pipe or any simple lever that increases your mechanical advantage sufficent to a force capable of spreading the bracket apart will work. HAHAH basically just use a bar to spread the bracket apart, but just go easy so you don't over due it. I just made it slightly wider and then tapped it home with a hammer. When you torque the track bar bolt you will close it back up any way but no use making a weak point in it. Good luck.
Old Jan 8, 2011 | 07:20 PM
TonyJeep75's Avatar
I gave it hell today but it was up on stands so I didnt go full force. Tomorrow morning I'll throw down with it.
Thanks for the help.
Old Jan 8, 2011 | 07:43 PM
Enzo's Avatar
thats good info to remember , hopefuly soon as I can get mine installed
