Found a Tire that I Like, BUT.....
My plan to get into 35's is within my grasp and I have the following upgrades ready to go:
1. Rugged Ridge 17X9 Black Satin wheels (X5)
2. Teraflex 2.5" Coil Lift w/Shocks
3. Step #3 is to purchase tires.
Issue - I am really liking the Nitto Trail Grapplers M/T and happened to see a set on a new JK at my local JCD yesterday. They are a beefy looking tire, but of course, it appears that a 35X12.50X17 is approx. 78 pounds, so I am greatly concerned around performance. I have the stock 4.10 w/automatic (which hurts - I know), so how bad would performance be considering all that I've done performance-wise, is a K&N drop-in and a Magnaflow exhaust? In addition, how bad would performance be until I could fund a Flashpaq?
Step #4 would end up being the Superchips Flashpaq post lift and tires.
Issue - I've read that several JK's can get by just with the Flashpaq until they could fund re-gearing, but taking into consideration, the Nitto weight and an automatic, would it be enough? Anyone running a similar configuration?
Step #5 would be to re-gear, but not for several months. Need to recover from several months of buying mods like, bumpers, winches, wheels, a lift, and more. (if the wife knew the extent, I might be living in my JK today
I know that KM2's and Duratracs are very popular, but I like the distinct look of this tire and don't want to have the same tire that I've seen alot of JK's running in my region.
Thanks for any input!
)I know that KM2's and Duratracs are very popular, but I like the distinct look of this tire and don't want to have the same tire that I've seen alot of JK's running in my region.
Go for the trail grappler's. I wheeled with em while on christmas leave for the first time, they shred grass and in 8 inches of mud they walked across it in 2 -wheel like I was on pavement. Just a whole hell of a lot messier.
Sent from my DROIDX using Tapatalk
Thanks for the input guys. To speak to the weight difference, it appears the KM2's are 68 lbs each so that would 40 lbs less and the Duratracs come in around 60 lbs, which is 72 lbs lighter. As long as my fellow JK'ers think I'll be alright, that's the path I'll take. I'll keep digging to see if there are any MPG results as well. Anyone else have input please respond. Thanks
i been running 35x12.50x18 mud grapplers for about a month with stock 3.73 . it did run a little under powered so i got superchips flashpaq and it felt almost back stock which still isnt saying much.
Last weakend got my 4.88 gears put in and the flashpaq and the gears. Yah thats where its at
35's on stock gears will kill your mpg's. Driving over 70ish will kill your mpg's. A lead foot will kill your mpg's. But an extra 40 or 50 lbs switching from one set of 35s to a different set of 35's? Not so much. (unless you are changing from a road friendly AT to an aggressive MT, maybe.)
You could also do a search on the Toyo MT. It's very popular, and about the heaviest tire out there, so maybe you could get some mpg feedback from those threads.
I read somewhere in the last few days, and I don't remember where and don't even know for certain how accurate this is, but this is food for thought: Each pound of tire weight is like carrying an extra ten pounds of cargo. So, are you happy with your Jeep's acceleration, gas mileage and braking when carrying an extra 720 pounds (say, four adult passengers)? Tire weight is one of the primary reasons I'm opting for the Duratracs.
