Advice needed... Proper components to do a 2.5" - 3" Lift Kit with 35" tires
Hey all,
So I am trying to forward plan a little here and have been reading a ton of threads and such trying to inform my self a little more about Jeeps and their suspensions.
As a Jeep newb I am overwhelmed at the amount of sheer information on this forum, wow! Its great, really is.
I am planning on getting into wheeling more but not quite as hard or intense some of you. This is my first Jeep that I have owned for about a month now.
I would like to put some 35" tires all around on the Jeep at some point and at the same time buy a set of 17" or 18" wheels and also get a lift kit done. Needless to say a little saving is in order to do all of the stuff at the same time.
My motto is do it right the first time. So here I am seeking some proper advice as what specific suspension components does it take to properly lift a Jeep 2.5" - 3".
I am really interested in doing the 2.5" Teraflex lift kit comes with:
Front and Rear Coil Springs
Front and Rear Bump Stops
Rear Brake Line Brackets
Rear Sway Bar Links
Rear Track Bar Bracket
Front and Rear Shocks
but could be swayed to do the 3" Teraflex coil lift which comes with if its worth it?:
Rear Sway Bar Links
Front Sway Bar Disconnects
Pair - Stainless Brake Lines
So here goes my question... what else do I need to get in terms of suspension components to make sure everything underneath is in spec and aligned like it should be so that there are no issues.
So far what I have gathered in terms of additional parts that I get and install are:
Adjustable front and rear trac bars
Various adjustable control arms.
And thats all I got so far.
Assuming the Jeep does 80% on road duty and some moderate 20% off-roading what suspension components are recommended in addition to getting say a Teraflex 3" or 2.5" coil lift kit....
FYI: I have 2dr, 6spd, Sahara.
Also any recommendations on components in addition to a lift kit that will level out the rake the Jeep has?
Appreciate the help from all in advance, THANKS!!!
Rear Sway Bar Links
Rear Sway Bar Links
Because you have a 2 door, you want the 2.5" Teraflex coil lift with shocks.
Although it would be nice to have an adjustable front trackbar and front lower adjustable control arms, they aren't really needed at 2.5"
At 2.5" with a 6 speed, you won't need to upgrade driveshafts.
If you want more articulation for offroading, then buy a pair of front JKS swaybar disconnects, install a pair of Bushwacker flat flares, and remove the front extended bumpstops that came with your TF lift.
At 3" on a 2 door, you really want the front adjustable trackbar and front lower control arms. If the shocks are long enough, you will end up needing a front driveshaft, and eventually, you will need a rear driveshaft and rear upper control arms.
Plus, at 3" on a 2 door, the rear springs tend to bow back more due to the rotation of the rear axle after you install a new rear driveshaft and rear upper control arms. So, you have to end up with some method of rear coil correction and coil retainers.
If you go with a 2.5" instead of a 3", you can allocate the saved $2000 for a front trackbar and future driveshafts, control arms, and rear coil correction toward regearing your rig to 4.88s, a Superchips Flashpaq, and a rear tire carrier.
I wont have any suspension alignment issues ?
thanks for the great reply btw.. informative.
Also any recommendations on components in addition to the 2.5" lift kit to level out the rake in the Jeep?
^^^ sounds great. thanks for replying!
You're welcome.
No. Your steering will be slightly more flighty than stock. You can toe-in about 1/16" using the self-alignment write-up on project-jk.com to minimize this.
If the flightiness is too much for you, you can always do front lower control arms and a front trackbar later, but most everyone running a 2.5" lift skips these because they are fine with how it handles without them.
I drove my 2 dr Rub for a long time on a 2.5" TF BB without an adjustable front trackbar or adjustable front lower arms with no problems at all. A couple times, I drove the 1600 mile round trip to Moab, wheeled it hard for a week, and returned home. It always felt very stable on the highway with 35s, and later 37s.
Any suggestions on components in addition to the 2.5" lift kit for levelling out the rake that the Jeep seems to have?
thanks again so much!
Speaking of bumper and winch.... does the extra added weight in-front call for any different kind of springs by any chance?
When you order, let David (northridge4x4.com) know how heavy a bumper and winch you are planning to run. He can let you know if you should run 4 dr front springs instead of 2 dr front springs.
I think I saw something about a big discount on Teraflex products through David.
However, I would highly discourage you from running a very heavy, full width bumper on a 2 door JK. It affects the handling more on the short wheelbase compared to a 4 door JK. My opinion. I'd rather have a stubby or mid-width bumper that is lighter.
Thanks again, I suppose this answers all my questions, lol...
Oh if anything, what about just getting the 4 door springs anyways even if I don't have a bumper and winch.... incase I later do get a front setup? Any negative's to running the 4 door springs without a bumper and winch?
Will re-bump this thread if I have any other questions and/or what I decide on in terms of parts and such!
Now I know what Im saving towards and do it all at once!
Thanks again! Happy Wheeling
