Teraflex 2.5 question
Old Jan 21, 2011 | 06:27 PM
gunbo75's Avatar
Default Teraflex 2.5 question
I HAVE A TERAFLEX 2.5 LIFT ON ORDER FOR A FOUR DOOR WITH A HARD TOP JUST CURIOUS HOW MUNCH LIFT WILL I GET OUT OF IT.SOMEONE TOLD ME I WOOD GET ONLY ABOUT 2".THANKS
Old Jan 21, 2011 | 06:32 PM
nycvr6's Avatar
I just installed a TF BB with shock adapters and I got 3" up front and 2.5" in the rear. Not sure why I got so much, but I measured.
Old Jan 21, 2011 | 06:38 PM
nthinuf's Avatar
How did you manage 3" with a 2.5" spacer?
You might try to find your caps lock button.
TF 2.5" coils should give right around 3" on a 4door, depending. (The 'new' 2door 2.5" coils are supposed to give right at 2.5". They might give you 2" on a 4door. Maybe.)
Old Jan 21, 2011 | 06:41 PM
loonies's Avatar
Depends...Tow package? Are the stock coils sagging? I have a 4-door Unlimited Rubi..no tow. Put a TF 2.5 Coil and only got about 2".
Old Jan 21, 2011 | 07:18 PM
Grognard's Avatar
I put a TF 3" lift on my rig and got over 4"
Old Jan 22, 2011 | 05:02 AM
MOPWR2U's Avatar
I got exactly 2.5" of lift out of my Teraflex 2.5" suspension lift.
Old Jan 22, 2011 | 05:32 AM
chipmaker's Avatar
3" from 2.5 TF coil
Old Jan 22, 2011 | 06:18 AM
snopro269's Avatar
I'm in process of installing a 4 door 2.5 coils with extensions on my two door. I have aftermarket front bumper and winch. 35 inch spare on rear. Northridge suggested for me to try it and see the measurements after install and after the coils settle what it is later on.
Old Jan 22, 2011 | 07:51 AM
nycvr6's Avatar
I think you asked me this already, I'm not sure to be honest. I didn't measure the exact height of the spacers, but I'm pretty sure the front spacers were taller than the rears. Here's a pic I took, it's hard to tell, but I should have measured them. The front spacer is sitting under the rear one in the picture.
Old Jan 22, 2011 | 07:52 AM
gunbo75's Avatar
thanks guys it is a coil lift
