Goodyear DuraTrac 285 70/R17 Air Pressure
Curious, what are the fellow Duratrac 285 70/17 owners running for air pressure levels? I'm looking for the pressure that I'd run for regular, street use - not off road.
Thanks in advance!
Sean
Thanks in advance!
Sean
Thanks in advance!
Sean
Thanks in advance!
Sean
Edit: just realized you're running a different size. Doubt it makes much of a difference.
I'm running them on a 16 inch rim, 35-38 is the perfect street range for comfort, tires wear better too. I ran then at 50-52 when I first got them, unless you like a stiff louder ride I would not suggest it.
Originally Posted by ECHO
Do a Chalk test and see hopw your set-up is , start at 30 psi & work your way up or down until you have all rubber (Tread) hitting the road.. I run my 35's at 26-28 psi
