what size spacers for rockstars?
Just pulled the trigger on the teraflex 3 inch kit and i plan on running 35x12.50 nitto mud grapplers on 18x9 kmc rockstars from what ive read it looks like id need a 1.5 inch spacers for both fron and rear am i right? i just wanted to clarify before i order the spacers? Thanks in advance for your help guys.
jimmy
jimmy
so no rubbing issues at all? I know alot of people are running them anyone else have the same luck with no rubbing? I just dont want to have any issues later on and end up replacing more stuff because of rubbing you know what i mean?
I run rockstars with 35x13.5 tires with no spacers and i rub at full lock on the sway bar on the street. The 3'' inch TF Kit is going to yield almost 4 and that kit comes with the appropriate bumpstops so you will be good
