To all RC 4in Xseries lift owners
Old Jan 25, 2011 | 05:29 PM
Default To all RC 4in Xseries lift owners
http://www.roughcountry.com/jeep_jk_4flex.html,Does this kit come with everything nessary to lift your jk(not including drive shafts). Did you buy anything else for this lift? Thanks for input.
Old Jan 25, 2011 | 05:33 PM
wayoflife's Avatar
JK-Forum Founder
it's a really complete kit. while not necessary, at this height, i might recommend adding a front track bar relocation bracket and dropped pitman arm or drag link flip to it. they will help keep make the handling of your jeep better.
Old Jan 25, 2011 | 05:38 PM
So it doesnt come with those things? i cant really identify the parts in that picture
Old Jan 25, 2011 | 05:39 PM
wayoflife's Avatar
JK-Forum Founder
looking at the pic, no, it doesn't and that's why i recommended it. like i said, it's not necessary but, it will help your ride and handling be better.
Old Jan 25, 2011 | 05:47 PM
Alright thanks, ill look into that around summer, im just getting a early start on parts searching, so that i can buy the jeep and then buy all the parts at once so that it will only be in the shed for a day or two on jacks and i can get it all at one time. 20 lug nuts isnt fun to undo a couple of tmes in a week
Old Jan 25, 2011 | 06:14 PM
A/C Guy's Avatar
I did not add the dropped pitman arm of drag link flip kit and my JK drives GREAT. I have driven on the freeway at 70 mph with no problems at all. I have driven in rock gardens and washboard dirt roads with no problems.
I did get the rear coil angle shims since so many other people have mentioned adding them to everyone's 4" lift.
I also added the wheel spacers since I haven't found any aftermarket rims that I like.
As I mentioned, my JK drives great. Get the kit now while it is on sale.
Old Jan 26, 2011 | 11:44 AM
Thanks for the input, I'm deffantly going with this kit,but i gotta buy the jeep first
Old Jan 26, 2011 | 12:14 PM
Originally Posted by sushi
you won't go wrong with the 4" x-series...don't worry about the drop pitman arm or a track bar relocation bracket.....It does great with everything that comes with it....I like the ride and the way it handles and performs off road....personally I feel it handles on road better than stock....Doesn't dart or act any different that stock...
Y'all guys are so helpful, glad someone had the bright idea to make a forum just for the greatest automobile on earth, the jeep jk!
Old Jan 26, 2011 | 12:18 PM
GatorLCA's Avatar
Definitely get the rear coil shims. It will help correct the bow-ing of the rear springs when you correct the pinion angle. You could also get JKS adjustable perches, but they're about $170 compared to $60 for the shims. The benefit to getting either is so the rear springs seat close to straight as possible because under full flex the rear track bar could get in the way
I also got the dual stabilizer cause even after my alignment there was still some shimmy in the wheel. Our roads are awesome down here
Old Jan 26, 2011 | 12:22 PM
I saw the thread for the shims and I'll add those to my list, and you live i'n Louisiana?
