6" X-series ROUGH COUNTRY LIFT QUESTIONS !!
Old Jan 26, 2011 | 10:07 AM
CUSTOM JK's Avatar
Default 6" X-series ROUGH COUNTRY LIFT QUESTIONS !!
Has anyone used one of these lift kits?? If so do you have to change the stock drive shafts?? Or does anyone recommend a different kit for comparable money. Thanks
Old Jan 26, 2011 | 10:33 AM
CA-JK's Avatar
I have the 4" kit, you'll need to change the drive shafts with the 6" kit. I love my kit, you'll not find a better kit for the money!
Old Jan 26, 2011 | 10:36 AM
Wolf Moon's Avatar
Hey, brother. I would definitely recommend swapping drive shafts w/ 6" of lift. I'm only going with 4" of lift on a 2-door, and I'll definitely need new drive shafts. As far as Rough Country quality? You should check out my RC vs. TF thread that I've had going for a couple days: https://www.jk-forum.com/forums/show...-Full-FlexArms Hope it helps. Good luck with your purchase!
Old Jan 26, 2011 | 10:47 AM
Rough_Country's Avatar
Sponsoring Manufacturer
On 6"s it is a must to change drive shafts. There is no work around for this one.
