RC 3.5" lift and trackbar question
I have the Rough Country 3.5" Series II lift and I plan on purchasing a JKS front adjustable trackbar before installing the lift. With the adjustable trackbar will I need to install the drop pitman arm and track bar drop bracket that is included with the kit? I am wanting to avoid death wobble.
I have the RC 3.5" series II lift and I had went the DW issues, So I had the Drop pitman arm and the Track Bar Bracket taken off and had the Adj. RC track bar put on. Then met a guy on here and he was able to find my DW problem, which was the track bar hole being wallowed out. So when you do this to save you problems, check your track bar bolt hole to make sure it is still round. Then make sure it is torqued to 125ft Lbs.
