OEM front driveshaft torque specs?
I removed my front drive shaft in an effort to eliminate causes of vibration after my lift. Would someone be so helpful as too explain in newbie English what the torque specs. for the bolts are so that I may reinstall the drive shaft?
Thanks for your time
Thanks for the quick reply!
I looked at this before on my Iphone while at work, got confused. I am assuming that:
Front Shaft - Axle Flange Bolts 110/81
Front Shaft - Transfer Case Flange Bolts 20/15
under the propeller shaft heading are the numbers I need. Is this correct? Just want to make sure.
Thanks again.
Thanks again.
