Driver side tire rubbing
Old Jan 27, 2011 | 11:30 AM
jphil's Avatar
Default Driver side tire rubbing
Hey guys I started to ask a lil about this prob. Then had some family issues and just getting back to fixing this prob on my 2010 jk rubi with a 4 in. Zone lift. I had wandering issues and drivability issues I have resolved thanks to the jk help from u guys. However when I say go thru a ditch and flex a lil my riverside tire rubs the rock slider I measured the distance from a set point on each tire front that is to the frame and adjusted my trac bar to get axle center and it still rubs. I don't have adjustable control arms and my tirea are 35x12.50 on 10" rims. Maybe axle still isn't centered? Thanks for the help.
Old Jan 27, 2011 | 11:34 AM
toymaster's Avatar
You need longer control arms so the axle is centered in the wheel well. Or, you can trim the rail and pinch seam.
Old Jan 27, 2011 | 11:51 AM
jphil's Avatar
Ok is it common to not rub on the other side
