Teraflex BB swaybar link
Old Sep 21, 2007 | 04:28 PM
Shaggycornbread's Avatar
Default Teraflex BB swaybar link
I installed the 2.5" BB lift and the rear swaybar links are very close to hitting the brake line at full flex. Is it necessary to use the longer ones that come with the kit or is it ok to use the stock ones?
Old Sep 22, 2007 | 08:13 PM
ThinkMud's Avatar
I put the longer ones on last week and wheel'd it pretty hard today, no problems with the longer links. You can also bend the brake line brackets out some to help clear stuff, mine are almost rubbing the shocks. I think the longer links help with wheel travel and stuff, but I may be wrong. A rule of thumb is that you want your sway bar to be as close to parallel to the ground or frame.
Old Sep 24, 2007 | 05:54 PM
Thanks for the help.
