Who has gone from 35" to 37" and why??
THis is the only decision holding me up. My wheels, fenders, bumpers, etc. are all here and paid for but I can't decide if I need the Rancho Long Arm and 37"s or a nice 3" kit and 35"s. Can some of you who have made the jump tell me what was behind your decision? I have seen pictures where 37s look way too big and some where they look just fine. The last thing I want is to spend money on a nice 3" lift and decide to go 37 because whatever I do I want to do right......long arm and all.
Thanks!
Thanks!
Good question... you can always go with a 3" with 35"s now. When/if you want to move up to 37"s you can either add a 1" spacer or get some new fenders, i.e. Xenon or PureJeep... and run 37"s on a 3" lift.
I went the 3" route with 35"s for now so I don't have to regear right now, the 4:10's are not bad with the 35"s but would not want to run them with 37"s.
Good luck with your decision, it's a hard one...
I went from 35's to 37's. I wanted/needed more ground clearance. I have the 3" Black Diamond Lift + the 1" M.O.R.E. body lift. I trimmed 1.5" off the stock Rubicon sliders, and about 1" off the pinch seam in the rear wheel well. I also sectioned about a foot off each end of my front bumper to keep my tires from rubbing on it. Other than that I can stuff the tires fully and the rear barely rubs, and the front slightly rubbed the inside of the fenders, but I added a .75" spacer yesterday and fixed that.
if i had a buck for everytime you've suggested a 6" lift.........
sorry for the hijack. i'm planning on working my way up from the 3" and 35's and see if i need the 37's later. 37's would be nice but can't see that it would be very practical on a dd. well, at least for me.
I went from 35's to 37's after finding that the 35's didn't give me the ground clearance I wanted. I added an additional 1" spacer up front and trimmed the inner fender a little, and cut the front bumper. In the rear I trimmed about 2" off the rear pinch seam at a 45 angle. The rear rubs the plastic fender liner a little, but no damage is done so I am living with it. The 37's also make a big difference in being able to "roll" over obstacles because the tire's approach angle is better. If I had it to do over again I would definately start with a 4-5.5" lift. (I did not say T-flex 6" longarm because FRDesign did, and it's not available yet). Around town there's really not much noticable difference in the 35's and the 37's. Going up a mountain or on the freeway, there is a noticable drop in power. It will still do 70 on the highway though so, again, I am living with it. I would regear if I had the cash, but there are other things I want to buy first. good luck with your decision.
I plan on going to 37's too, after my 35's are done. No cash to upgrade gears yet. Plus I'd like to build a D44 for the front.
pulmano1, how do you like the 5:13's with the 6spd and 35's? I can't deside betwwen thse and 4:88's. How far off is your speedo. I drive ALOT, and don't want to give Jeep any extra miles off of my warrantee.
I think the 5.13's are a little much for the 35's (biggest complaint is highway rpms), but would be great for the 37's. If you drive alot, I would prob go with the 4.88's. My speedo is off about 3 mph (with my GPS). I went with 5.13's b/c I thought it gave me the best option based on mostly local driving, knew I was eventually go 37's, and it crawls like a champ.
