T.W. D.S. Silicone?
Installation of the Tom Woods drive shaft calls for silicone for the Flange. I don't want to put the wrong stuff in there. Do I need silicone gasket maker or silicone lube?
I don't recall that step. Is it talking specifically about grease? And does it actually say 'flange'? I assume that it was shipped with yokes?
If it is about the grease, Tom has some info on his website about grease and maintenance. May be worth a few minutes to look through it all.
I went with Lucas Red N Tacky, just because that was the best that was available at my local parts store. A lot of people recommend white lithium. And I think northridge carries a good grease that you could check out.
Frequent greasing is more important than type of grease.
High temperature rating is important. 300+ is what you want.
what he said - basically, you want to use RTV and NOT grease.
Originally Posted by TheDirtman
as long as you don't see gear oil seeping out around your pinion nut you should be fine.
