Suggestions for track bars and brakets
Old Sep 24, 2007 | 04:18 PM
tshuelsman's Avatar
Default Suggestions for track bars and brakets
I am looking for suggestions on track bar brackets and new track bars. Front and rear.
What is everybody using. and what are the problems.
I've seen a couple threads about the front and rear track bar welds braking. looking for suggestions.
pictures please
Old Sep 24, 2007 | 04:27 PM
wayoflifette's Avatar
JK-Forum Founder
Not sure what you are looking for, but Currie has some weld on relocation brackets for the front and rear track bars. Here are some pics:
Old Sep 24, 2007 | 05:58 PM
medbender's Avatar
if you just want a track bar for your lift and nothing extream, go with full traction adj. bars. you should be able to use the factory brackets without relocators and they should hold up well.
Old Sep 24, 2007 | 08:39 PM
tshuelsman's Avatar
If i have a 4 inch skyjacker coils, do i still need to keep my track bar brackets that were included in my skyjacker kit. If i were to order Full traction front and rear track bars?
Are the front and rear Full traction bars a direct fit with my skyjacker coils, or does Full Traction make there own brackets?
Old Sep 25, 2007 | 09:30 AM
easttnruby's Avatar
I had the relocation brackets first and they were lame. Not for any type of heavy duty abuse, but that is merely my opinion. Now have the adjustable Full Traction bars front and rear and love them. Axles are totally centered and have no problems with at all. My front one does rub slightly on the SOLID diff cover though but nothing bad.
Old Sep 25, 2007 | 09:40 AM
Piginajeep's Avatar
track bars will work with your skyjacker kit, its not connected to the lift.
Old Sep 25, 2007 | 10:39 AM
David @ Currie Ent.'s Avatar
Former Vendor
Keep in mind that if you are using a drop pitman arm and no trac bar relocation bracket in the front you will get bump steer!!
Old Sep 25, 2007 | 11:55 AM
Jake_Blues's Avatar
Or vice versa (track bar relocation bracket and no drop pitman arm).
-E
Old Sep 26, 2007 | 05:14 AM
troy_boy's Avatar
When you say drop pitman arm, you mean longer than stock? I cant remember if my kit had an aftermarket pitman with the 3" lift, I put adjustable t-bars and removed the relocation brackets. Will someone please measure the original pitman so I can compare....Thanks
Old Sep 26, 2007 | 09:20 AM
tshuelsman's Avatar
thanks for the advise from everybody.
