Best after market ball joints Trying to fix the off Camber stockers..
Old Mar 1, 2011 | 01:28 PM
Ronstar83's Avatar
Default Best after market ball joints Trying to fix the off Camber stockers..
I have looked into a few options today and would like to know what JK owners are using. None of them seem to say they are adjustable? Should you replace both upper and lower? Thanks!
Old Mar 10, 2011 | 04:21 PM
BigBallin's Avatar
anyone?
10char
Old Mar 10, 2011 | 04:37 PM
Dynatrac's Avatar
Sponsoring Manufacturer
The adjustable ball joints you will find are stock quality. The factory housing and end forgings are bending and this is causing the camber issues. Many times even the adjustable ball joints will not fix the problem as they can only correct a couple of degrees of camber.
Old Mar 10, 2011 | 06:04 PM
mkjeep's Avatar
I run the Napa adj uppers, they are of high quality and are greasable. But..I'm stuck with the oem solid lowers.
Moog also makes a quality greasable adj lower. There are other adj ball joint brands out there that are cheaper than either the moog or the napa, but they are not greasable and about equal to the oem quality wise.
