Am i right?... For a newbie
Originally Posted by TheDirtman
Was it death wobble or bump steer? death wobble won't stop until you really slow down. Bump steer is just momentary from hitting the bump in the road. With a 4" lift you will get bump steer pretty bad until you do a drag link flip to correct the steering geometry.
Watch this vid that TF put together, then take a pic of your front end and compare.
http://rides.webshots.com/video/3016...02496289IjoMUo
You are right in wanting to check the torque on everything, but I do not believe all the components you are interested in torque to 120lbs. Specifically, I believe the upper control arms are lower, in the 75lb range...
Check this out: http://project-jk.com/jeep-jk-write-...orque-settings
That should list all the proper torque specs you'd be interested in.
Not everything gets 120lbs of torque, here is a great reference!
That has all of the specified torque settings, and yes it is a good idea to re-torque everything after a wobble, off-roading trip, or oil change!
