Performance Chip for Jeep
Old Sep 25, 2007 | 12:18 PM
Rebel Heart's Avatar
Default Performance Chip for Jeep
I am considering having a performance chip installed. I understand there are a couple of different versions. Any suggestions? Is it worth using premium fuel? I am also planning to install headers and a cat-back system.
Old Sep 25, 2007 | 12:33 PM
nate1235's Avatar
i havent gotten a chip yet but have a cat back exhaust and new headers. the headers are kinda hard to put on but definetely worth it. the power gains are good. i heard unichip is a good chip for the jk
Old Sep 25, 2007 | 01:11 PM
dern's Avatar
I have a Jet stage II Chip with cai & cat back exhaust. The chip made a big change for the better.
Old Sep 25, 2007 | 06:47 PM
Where is the best place to purchase a chip? I'm not familiar with the best chip makers. I see a Jet stage II chip was recommended. What is the price?
Old Sep 26, 2007 | 11:09 AM
John L's Avatar
How's the heat with the headers? I read somewhere that another member melted the bottom of his battery box.
Old Sep 26, 2007 | 11:14 AM
jameswharton's Avatar
I did and I had to make a heat sheild to protect what was left of it. Gibson is now going to include a heat sheilds in the kit.
Jim
Old Sep 26, 2007 | 01:01 PM
Are most going with the stageII chip? I know this requires 91 octane. Is there are a noticeable difference between stage 1 and stage II?
Old Sep 26, 2007 | 02:25 PM
nate1235's Avatar
Default chip
u need some extras if u go with the stage 2 whereas if u dont have a new intake and cat back exhaust ect. you go with the stage 1. by the way, the new headers havent melted my battery....yet
Old Sep 26, 2007 | 03:20 PM
SH0RTBUS's Avatar
I'm not buying the 91 octane BS. There is no reason to run higher octane unless you are running substantially higher compression, and you are not unless you increase the stroke or add forced induction. Octane increases the fuels resistance to pre-detonation (ie. combusting on the compression stroke due to increased heat from higher pressure). A high octane fuel does NOT provide more power or a cleaner burn. Save your money and just run 87. I have used nothing but 87 in all of my vehicles and sportbikes without ANY issues what so ever.
Old Sep 26, 2007 | 07:02 PM
07 RBY's Avatar
Somebody correct me if I'm wrong, but the reason for the octane increase is due to the timing being changed. It avoids detonation by using higher octane fuel.
