Is this wheel too wide for stock tires???
Old Mar 1, 2011 | 05:59 PM
20JK10's Avatar
Default Is this wheel too wide for stock tires???
I really like the design of the ProComp 7069 as seen here
http://www.quadratec.com/products/92819_2903_07.htm
I was wondering if this wheel is too wide for the stock 255/75/17 M/T's? I do plan on upgrading to 33's when I either get the money or when the tires wear down.
Old Mar 1, 2011 | 06:08 PM
nthinuf's Avatar
Go to the mfg's website and look at the specs for that tire. It will show the recommended rim width range. Without looking, I will say yes, those rims are wider than the mfg's spec, so check around with your local shops to find one that doesn't have an issue mounting them.
Old Mar 1, 2011 | 06:11 PM
jesse0376's Avatar
go to a conversion chart the tire is 10 wide and the wheel is 9 wide should be fine.
Old Mar 1, 2011 | 06:15 PM
Merlin4979's Avatar
If they're the BFGoodrich Mud Terrain's, then the widest recommended wheel is 8.5", so that wheel you're looking at would be too wide.
http://www.bfgoodrichtires.com/tire-...m/tire-details
Old Mar 1, 2011 | 06:27 PM
ditchdigger's Avatar
If your running the stock BFG mud terrains i believe the rim range is 6.5" - 8.5", but i would look on there website and look at thew spec's.
Old Mar 1, 2011 | 06:29 PM
nthinuf's Avatar
Max recommended width for my 10.5" claws is 9 and I'm on 10. It can be done.
Can they be installed? Yes.
But as noted above, some shops will refuse to mount them. Just like some shops will refuse to deal with wheel spacers. Or rims that are narrower than the mfg's spec for a certain tire.
Old Mar 1, 2011 | 06:31 PM
Jknockers's Avatar
I ran BFG's 31x10.50x15 on a 10" rim before on a blazer, they were fine, You will be fine with that tire on a 9" rim, I would do it,
Old Mar 2, 2011 | 05:30 AM
20JK10's Avatar
I have a place to mount them, just wondering if the wheel is too wide.
