How much lift with stock driveshafts
Old Mar 2, 2011 | 02:37 PM
D_engel's Avatar
Default How much lift with stock driveshafts
Hey guys, I plan on getting a RC 2.5 coil lift with teraflex adjustable LCA's, and JKS adjustable track bars front and rear. I also want to use 1 inch coil spacers from my leveling kit. I dont do super serious wheeling and I want to know if I will be safe running this setup on factory drive shafts?
Old Mar 2, 2011 | 02:59 PM
D_engel's Avatar
gotcha. Looks like ill be keeping it around 3 inches instead.
Old Mar 2, 2011 | 03:26 PM
Kevo's Avatar
i got 5.5" lift and have had no issues in 75,000 miles
Old Mar 2, 2011 | 03:29 PM
tjwillmann07's Avatar
Default Lift and driveshafts
I have 3.5 inches of lift and no issues at all go with the the 3.5 becuse later down the road will wish u have...
Old Mar 2, 2011 | 03:40 PM
DJjeep's Avatar
I have a rc 4" lift with 20,000 miles no problems so far with stock shafts
Old Mar 2, 2011 | 03:41 PM
russcox1's Avatar
i have around 4+ inches of lift and stock shafts with 30,000 miles with lift... no problems ever
Old Mar 2, 2011 | 03:42 PM
remark's Avatar
You also have to watch out on some autos the boot gets ripped on one of the transmission pan bolts. So the 3.5" thing really isn't a magic number.
Old Mar 2, 2011 | 03:56 PM
nthinuf's Avatar
What he said. There is no magic number, but there are builds that would be more likely or less likely to need new driveshafts.
Total lift height
Shock length
Axle centering
Type of driving
JK model
--> Luck
etc.
Old Mar 2, 2011 | 04:36 PM
KWITURBITCHN's Avatar
i also have 6in, 68,000 miles on the lift, and 81k total.and no problems... i have the auto. i just put some 1inch spacer for my cross brace to clear the front drive. the boot is still intack. my front shaft is at a very steep angle. 1 day i plan on installing a new front cv style shaft.
Old Mar 2, 2011 | 06:30 PM
D_engel's Avatar
So there seem to be quite a few variables. I have a manual so I dont need to worry about the trans cross member issue the automatics have, and Im doing adjustable track bars so my axles should be perfectly centered. Im also going to use the shocks that come in the kit so I wont be maximizing my droop to its full potential. I feel pretty confident with this setup after reading your responses. This is my DD so im trying to make sure I get everything right the first time.
