will my stock drive shafts last
Old Mar 3, 2011 | 11:05 AM
orangecrush's Avatar
Default will my stock drive shafts last
I am thinking of up grading from a 2 inch mopar lift to a 4 inch teraflex on my 4 door jk. does anyone know if i need to get new drive shafts also or will i be ok with the stock ones..
Old Mar 3, 2011 | 11:07 AM
wazooz2424's Avatar
manual or auto? NM, your profile says auto. you will eventually need a front ds.
Old Mar 3, 2011 | 11:08 AM
nthinuf's Avatar
Plan on getting around 5" from those coils. Your rear shaft should last a while, the front more than likely will not.
With a bit over 3", I lost my front driveshaft at about 6k miles.
Old Mar 3, 2011 | 11:16 AM
Pluke the 2's Avatar
yup. trust the above info.
https://www.jk-forum.com/forums/show...ye-Drive-Shaft
Old Mar 3, 2011 | 11:22 AM
GreenJK07's Avatar
This is correct and it's pretty much safe to say that any lift over 3" needs a front shaft and the rear shaft's life is limited and will need replacing in a matter of time.
Old Mar 3, 2011 | 11:23 AM
Abacabb's Avatar
You won't need to replace them right then and there.
Eventually you will need to get after market drive shafts though.
Old Mar 3, 2011 | 05:08 PM
renpia's Avatar
The TF 4" nets you more like 5.5" so plan for it. The center boot will tear off when disco'd and fully flexed (hits the oil pan and skid) and the cv boot will eventually tear and spit out grease near the Tcase and eventually fail. You can run it for a long while if you don't wheel it. But if you plan on wheeling, you might as well get it off the bat.
Old Mar 3, 2011 | 05:20 PM
gripthor's Avatar
You won't need to replace them if you don't disconnect your sway bar and stay on the pavement.
Old Mar 3, 2011 | 08:32 PM
this is false. stock drive shafts will die from angles as mentioned above without disconnecting.
Old Mar 3, 2011 | 08:42 PM
Sunnysideup's Avatar
JK-Forum Ambassador
My front one is throwing grease and I have less than 1000 miles on it since the 4 inch lift. Happens pretty fast after you lift it. No hard-core wheeling in those miles, it just didn't make it very long.
