OK way of life r ribimon
Heres the deal < I would like to know , the best lift I could do 5 -6 inches, If I could use my RE BB, and what other alterations, would be the best bang for my buck( mostly muddin not rock jocking). Do U know r am I out on a hanger since the JK is mostly new?
5"-6" of lift is a LOT of lift. Are you planning on running 40" tires because that's what a lift this tall would be good for. And, if you really are going this tall, I would definitely NOT use the BB that you have now in conjunction to something else to get there. At this height, you really should consider getting a long arm kit which will essentially replace everything you have now and replace them with what you will need.
