Build D44 or buy?
I have a Rubicon D44 with 5.13 gears, the e-locker, c-reinforcements an ARB cover, a Currie HD tie rod and the drag link flip + a sleeve that allows a stock height rig to run the normal drag link configuration.
I am now at a cross roads. I can either build the D44, buy a HD D44, or buy a D60. I already run 5x5.5 wheels and want manual hubs so any of the three routes would end up with them.
Option 1: Build existing D44 with the solid hub conversion, an ARB, new chromo inner shafts and an axle sleeve kit.
Option 2: Buy a HD 44 with the same set up as above but with full 60 outers. This should prove much stronger, but cost more.
Option 3: Buy a D 60 with everything above, but full 60 components.
I estimate the cost for #1 above to be about $4000. The cost for #2 is about $6300 and the cost for #3 is about $7200.
If I can get 1500-2000 for my axle as it sits why would I build it when I can almost step across to the new 44, or for "only" a few hundred more, get the 60 and be done with it.
I run 38" tires and about 5.5" of lift currently and don't plan to go bigger. I do plan to run front coilovers at some point. I run dual 60's on my other jeep with 37's and have never broken anything. It has coilovers.
What are your thoughts and opinions?
Option 1 is a waste of money. Option 2 would work, but with the manual hubs, it is so close to option 3 that it doesn't make a lot of sense. (A direct swap into an off the shelf PR44 for 2k would make sense, but not a custom build with 60 ends.)
Go for option 3.
Go for option 3.
So, #1 is sleeves, Super 44, and Spyntec?
#2 is ProRock 44 built disc to disc with lockout hubs, ARB/Super44?
#3 is Currie, Dynatrac, or Solid built disc to disc?
Do you already have hydro assist?
I'm on my phone. So, I don't see your build specs.
Sent from my DROIDX using Tapatalk
if you do get a new front axle depending on the time, I may be interested. Timing is everything and cost. The other thing to think of is, why wouldn't someone else just spend the few extra $$$ and buy new. The educated person will buy the new over used.
Option 1: Build existing D44 with the solid hub conversion, an ARB, new chromo inner shafts and an axle sleeve kit. Unless you remove and re-install the factory 'C's, you still have bad castor angle. If you haven't already changed them out, at some point you'll be changing nearly every bracket on the housing. I think your $4k price is a little light unless you're doing all the work. After all the work and cash you'll have in it, it will still be a factory 44 worth less than $3k when you go to sell it.
Option 2: Buy a HD 44 with the same set up as above but with full 60 outers. This should prove much stronger, but cost more. This will cost nearly as much as a 60 but should be enough for 38's. The advantage is a much lighter housing and better ground clearance than even our ProRock 60. To date, I've heard of 1 (yes one) JK 44 front gear set failure with any size tire. The JK 44 HP front gear set has proven to be very reliable(the rear-not so much).
If I can get 1500-2000 for my axle as it sits why would I build it when I can almost step across to the new 44, or for "only" a few hundred more, get the 60 and be done with it. This can also be a good choice as you can grow into it. It will easily support a Hemi conversion later. The 60 front will be wider than your 44 and you'll want to use spacers on your rear 44 until you upgrade it to a 60.
I know it sounds stupid and conceited but when I spend a load of money I want to be able to see it. If I spend $,$$$ on a front end I want to be able to see that it's not stock under there. I can't tell you how many guys I've talked to that have said that after they installed their ProRocks, they would go out into the garage and stare at them for hours.
