Two Door hole in the rear of tub.
Old Mar 10, 2011 | 04:25 PM
woo1517's Avatar
Default Two Door hole in the rear of tub.
in the two door jk's there is this hole in the tub on both sides under the carpet. I guess it's about 2x5 inches. will this fill up with water, cause other problem? is there any way for water to drain out of it? And does anyone know of a way to plug it, or even turn it into a storage area. I thought a boat storage hatch kinda thing would be cool, but those are usually circles. here are some pictures to show.
ID:	136162Click image for larger version
Old Mar 10, 2011 | 04:30 PM
woo1517's Avatar
Originally Posted by TheDirtman
That area is filled with foam. The factory had a rubber cover over it but it looks like it was removed to do the lining. You might want to buy a pint of brush on bed liner and give the foam a couple of coats to seal it off.
That's all I need. A rubber cover like the drain plugs in the floor. I took the carpet out and I never have rubber covers on it.
Old Mar 10, 2011 | 04:36 PM
woo1517's Avatar
here is what it looks like.
Attachment 136165
Man that looks like it is glued in or something. I was hoping it would be like the floor drain plugs where you can pop it in and out.
